How to remove specific panel icons?
Re: How to remove specific panel icons?
Post by aimeos » 03 Nov 2020, 08:23
Configuration settings added in Aimeos extensions are merged together so it doesn't change anything if you copy the file and remove some entries. To remove settings, you have to add the new configuration to your ./config/shop.php file. Settings there take precedence over settings from extensions.
Post by aimeos » 07 Nov 2020, 08:45
Use this in your Laravel ./config/shop.php file and remove the panels you don't want to show:
'admin' => [
	'jqadm' => [
		'navbar' => [
	0 => 'dashboard',
	10 => 'order',
	20 => 'customer',
	30 => 'product',
	40 => 'catalog',
	50 => 'attribute',
	60 => 'coupon',
	70 => 'review',
	80 => 'subscription',
	90 => 'supplier',
	100 => 'service',
	110 => 'plugin',
	120 => 'group',
	130 => [
		'' => 'locale',
		10 => 'locale',
		20 => 'locale/site',
		30 => 'locale/language',
		40 => 'locale/currency',
	140 => [
		'' => 'type',
		10 => 'type/attribute',
		20 => 'type/attribute/lists',
		30 => 'type/attribute/property',
		40 => 'type/catalog/lists',
		50 => 'type/customer/lists',
		60 => 'type/customer/property',
		70 => 'type/media',
		80 => 'type/media/lists',
		90 => 'type/media/property',
		100 => 'type/plugin',
		110 => 'type/price',
		120 => 'type/price/lists',
		130 => 'type/price/property',
		140 => 'type/product',
		150 => 'type/product/lists',
		160 => 'type/product/property',
		170 => 'type/service',
		180 => 'type/service/lists',
		190 => 'type/stock',
		200 => 'type/tag',
		210 => 'type/text',
		220 => 'type/text/lists',
	150 => 'log',
