Price format
Price format
Hello, how can prices format be set with 100,00 on 100?
Re: Price format
The number format is created by a view helper which has a second parameter for the number of decimals:
You have find the implementation here:
https://github.com/aimeos/aimeos-core/b ... Locale.php
$this->number( 100, 2 )https://github.com/aimeos/aimeos-core/b ... Locale.php
Re: Price format
Thank you very much for your help!aimeos wrote: ↑07 Nov 2020, 07:55 The number format is created by a view helper which has a second parameter for the number of decimals:You have find the implementation here:Code: Select all
