Search bar to the top
sudinmanandhar
Post by sudinmanandhar » 22 Nov 2020, 14:08
Hi ,
I'm new with Aimeos. I was trying to move the search bar to the top of the menu but could not do it.
I added some text on this file but it does not changes when I refresh the page. Am I editing the correct file ?
project\ext\ai-client-html\client\html\templates\catalog\filter\attribute-body-standard.php
I saw the following code:
@section('aimeos_nav')
    <?= $aibody['catalog/filter'] ?>
@stop
What does the this array means ? Please help
"php": "^7.2",
        "aimeos/aimeos-laravel": "~2020.07",
        "fideloper/proxy": "^4.0",
        "laravel/framework": "^6.0",
Re: Search bar to the top
Post by aimeos » 23 Nov 2020, 17:32
sudinmanandhar wrote: 22 Nov 2020, 14:08 I'm new with Aimeos. I was trying to move the search bar to the top of the menu but could not do it.
This file is for the attribute based faceted search filter. For the search bar its:
ext\ai-client-html\client\html\templates\catalog\filter\search-body-standard.php
Furthermore make sure that you disabled caching during development:
https://github.com/aimeos/aimeos-laravel#hints
@stop
This outputs HTML of the complete catalog/filter component. If you only want to use the search bar, you can add "<?= $aibody['catalog/search'] ?>" instead if you configure "catalog/search" instead or additionally to "catalog/filter":
https://github.com/aimeos/aimeos-larave ... hp#L24-L33
Please read this article to understand how you can adapt it to your needs:
https://aimeos.org/docs/latest/laravel/extend/
