Customise Base Blade on Aimeos
Maryam DY
Post by Maryam DY » 02 Dec 2020, 06:54
Hello
Would you please help me find out How to customise base blade and use my application base blade instead with no errors?
when I replace my blade in aimeos blade I get errors of variables not found, how can I add my variables or where I should add them to be able to see by base blade as an original layout?
Re: Customise Base Blade on Aimeos
Post by aimeos » 03 Dec 2020, 09:25
Can you please post your Blade file and your ./config/shop.php "page" section?
Maryam DY
Post by Maryam DY » 16 Dec 2020, 22:47
HI I sent you a private message and replied to the last request few days a go, I just wanted to know if you have received my post?
Maryam
makkam
Post by makkam » 17 Dec 2020, 02:39
just you should not mess any required variables ..
but in general , do you want to update original existing Aimeos files ?
or make a new extension to avoid updating original files and specify all changes in one extension ?
Maryam DY
Post by Maryam DY » 17 Dec 2020, 04:52
sorry I forgot to send you my blade file I will send it in private section now, in regards to your question, I'm trying to have all the Aimeos components work within my base blade file, instead of Aimeos base Blade file.
Maryam DY
Post by Maryam DY » 17 Dec 2020, 05:49
HI My private responses goes to outbox any idea why i can not submit my messages?
makkam
Post by makkam » 17 Dec 2020, 10:57
ok ,
firstly .. which file do you want to edit ? give me its name and path ..
about outbox problem .. I dont know ... but no need till now for it
