Move catalogs data from one store to another
traiyani75
Post by traiyani75 » 18 Dec 2020, 11:35
We want to move all catalogs data from one store to another store. Can you please help us for the process?
Re: Move catalogs data from one store to another
Post by aimeos » 20 Dec 2020, 13:16
You can use the catalog and product XML export/import. It's not documented well yet but it's pretty easy to use. You only have to configure the location where the files should be stored/read from:
- Product export location: https://aimeos.org/docs/2020.x/config/c ... /#location
- Product import location: https://aimeos.org/docs/2020.x/config/c ... location_1
- Catalog export location: https://aimeos.org/docs/2020.x/config/c ... /#location
- Catalog import location: https://aimeos.org/docs/2020.x/config/c ... location_1
Then, execute the jobs, e.g. for Laravel:
php artisan aimeos:jobs "product/xml/export catalog/xml/export"
php artisan aimeos:jobs "product/xml/import catalog/xml/import"
You can also add the site at the end of the commands for export/import a specific site.
traiyani75
Post by traiyani75 » 21 Dec 2020, 07:12
Thanks for the suggestion. We were checked export product document.
But, It doesnt support export product with properties. Right now, it is exported with attribute, media, text, price and sub products.
https://aimeos.org/docs/2020.x/config/c ... /#partials
How do we export properties along with other partials?
Post by aimeos » 22 Dec 2020, 11:12
The "product/property" should be added here:
https://github.com/aimeos/ai-controller ... d.php#L282
Can you create a pull request on Github with the change? We will integrate it and release a new version.
