Problem using multiple basket - cannot save basket
FaheemAbrar
Post by FaheemAbrar » 04 Jan 2021, 05:10
Aimeos Version: 2020.10
PHP version: 7.4
Environment: Windows 10 WSL2
According to aimeos docs, we can create multiple baskets by passing different values for the "id" parameter, e.g.
curl -b cookies.txt -c cookies.txt \
-X GET 'http://localhost:8000/jsonapi/basket?id=second'
When I try to use this functionality to work with a basket of custom ID, I encounter problem when I try to save the basket.
Everything works fine for the other basket functionalities - products are added properly, delivery and payment address added properly, delivery and payment method added properly. However, when I try to use the basket resource href to save the basket, I always encounter the following error -
Basket empty
I tried using the basket without a custom ID, and saving the basket worked flawlessly in this case. The problem only occurs when I define a custom basket ID to get multiple baskets.
Can anyone please help me out here?
Re: Problem using multiple basket - cannot save basket
Post by aimeos » 05 Jan 2021, 17:35
Can you please investigate a bit further what might be the problem?
A JSON API POST request to store the basket is done here and uses the custom ID:
https://github.com/aimeos/ai-client-jso ... d.php#L191
The store() method of the basket frontend controller is implemented here:
https://github.com/aimeos/ai-controller ... d.php#L122
Does the error (exception) occurs in this line?
https://github.com/aimeos/ai-controller ... d.php#L180
or in that line?
https://github.com/aimeos/ai-controller ... d.php#L183
You should also enable the debug setting of the JSON REST API to see the stack trace:
client/jsonapi/debug => 1
Can you post the stack trace that is then returned?
FaheemAbrar
Post by FaheemAbrar » 14 Feb 2021, 19:27
Apologies for the delay. I have described the error in detail below, and also propose a solution for it.
The error happens in the following link -
https://github.com/aimeos/ai-client-jso ... d.php#L188
Here's the error from the json response -
"errors": [{"title":"Basket empty","detail":"#0 \/app\/ext\/ai-client-jsonapi\/client\/jsonapi\/src\/Client\/JsonApi\/Basket\/Standard.php(188): Aimeos\\MShop\\Order\\Item\\Base\\Standard->check()\n#1 \/app\/vendor\/aimeos\/aimeos-laravel\/src\/Aimeos\/Shop\/Controller\/JsonapiController.php(72): Aimeos\\Client\\JsonApi\\Basket\\Standard->post()\n#2 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Controller.php(54): Aimeos\\Shop\\Controller\\JsonapiController->postAction()\n#3 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/ControllerDispatcher.php(45): Illuminate\\Routing\\Controller->callAction()\n#4 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Route.php(254): Illuminate\\Routing\\ControllerDispatcher->dispatch()\n#5 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Route.php(197): Illuminate\\Routing\\Route->runController()\n#6 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Router.php(693): Illuminate\\Routing\\Route->run()\n#7 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(128): Illuminate\\Routing\\Router->Illuminate\\Routing\\{closure}()\n#8 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Middleware\/SubstituteBindings.php(50): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#9 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Illuminate\\Routing\\Middleware\\SubstituteBindings->handle()\n#10 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Middleware\/ThrottleRequests.php(127): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#11 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Middleware\/ThrottleRequests.php(103): Illuminate\\Routing\\Middleware\\ThrottleRequests->handleRequest()\n#12 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Middleware\/ThrottleRequests.php(55): Illuminate\\Routing\\Middleware\\ThrottleRequests->handleRequestUsingNamedLimiter()\n#13 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Illuminate\\Routing\\Middleware\\ThrottleRequests->handle()\n#14 \/app\/vendor\/laravel\/sanctum\/src\/Http\/Middleware\/EnsureFrontendRequestsAreStateful.php(33): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#15 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(128): Laravel\\Sanctum\\Http\\Middleware\\EnsureFrontendRequestsAreStateful->Laravel\\Sanctum\\Http\\Middleware\\{closure}()\n#16 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Foundation\/Http\/Middleware\/VerifyCsrfToken.php(78): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#17 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\VerifyCsrfToken->handle()\n#18 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Session\/Middleware\/StartSession.php(121): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#19 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Session\/Middleware\/StartSession.php(63): Illuminate\\Session\\Middleware\\StartSession->handleStatefulRequest()\n#20 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Illuminate\\Session\\Middleware\\StartSession->handle()\n#21 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Cookie\/Middleware\/AddQueuedCookiesToResponse.php(37): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#22 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Illuminate\\Cookie\\Middleware\\AddQueuedCookiesToResponse->handle()\n#23 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Cookie\/Middleware\/EncryptCookies.php(67): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#24 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Illuminate\\Cookie\\Middleware\\EncryptCookies->handle()\n#25 \/app\/vendor\/laravel\/sanctum\/src\/Http\/Middleware\/EnsureFrontendRequestsAreStateful.php(26): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#26 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(149): Laravel\\Sanctum\\Http\\Middleware\\EnsureFrontendRequestsAreStateful->Laravel\\Sanctum\\Http\\Middleware\\{closure}()\n#27 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#28 \/app\/vendor\/laravel\/sanctum\/src\/Http\/Middleware\/EnsureFrontendRequestsAreStateful.php(34): Illuminate\\Pipeline\\Pipeline->then()\n#29 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Laravel\\Sanctum\\Http\\Middleware\\EnsureFrontendRequestsAreStateful->handle()\n#30 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#31 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Router.php(695): Illuminate\\Pipeline\\Pipeline->then()\n#32 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Router.php(670): Illuminate\\Routing\\Router->runRouteWithinStack()\n#33 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Router.php(636): Illuminate\\Routing\\Router->runRoute()\n#34 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Routing\/Router.php(625): Illuminate\\Routing\\Router->dispatchToRoute()\n#35 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Foundation\/Http\/Kernel.php(166): Illuminate\\Routing\\Router->dispatch()\n#36 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(128): Illuminate\\Foundation\\Http\\Kernel->Illuminate\\Foundation\\Http\\{closure}()\n#37 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Foundation\/Http\/Middleware\/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#38 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()\n#39 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Foundation\/Http\/Middleware\/ValidatePostSize.php(27): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#40 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\ValidatePostSize->handle()\n#41 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Foundation\/Http\/Middleware\/PreventRequestsDuringMaintenance.php(86): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#42 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\PreventRequestsDuringMaintenance->handle()\n#43 \/app\/vendor\/fideloper\/proxy\/src\/TrustProxies.php(57): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#44 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Fideloper\\Proxy\\TrustProxies->handle()\n#45 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Http\/Middleware\/TrustHosts.php(48): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#46 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Illuminate\\Http\\Middleware\\TrustHosts->handle()\n#47 \/app\/vendor\/fruitcake\/laravel-cors\/src\/HandleCors.php(57): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#48 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Fruitcake\\Cors\\HandleCors->handle()\n#49 \/app\/vendor\/sentry\/sentry-laravel\/src\/Sentry\/Laravel\/Tracing\/Middleware.php(46): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#50 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(167): Sentry\\Laravel\\Tracing\\Middleware->handle()\n#51 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Pipeline\/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()\n#52 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Foundation\/Http\/Kernel.php(141): Illuminate\\Pipeline\\Pipeline->then()\n#53 \/app\/vendor\/laravel\/framework\/src\/Illuminate\/Foundation\/Http\/Kernel.php(110): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRouter()\n#54 \/app\/public\/index.php(52): Illuminate\\Foundation\\Http\\Kernel->handle()\n#55 {main}"}]
The problem here is that when
$this->controller->get()->check()
is called, the controller does not have the basket id set at that point, so the controller thinks the basket is empty. The solution is to set the basket id in the controller before the check function is called, e.g.
try
		        $this->controller->setType( $view->param( 'id', 'default' ) );
			$this->controller->get()->check();
			$this->clearCache();
			$item = $this->controller->store();
			$this->getContext()->getSession()->set( 'aimeos/order.baseid', $item->getId() );
			$view->item = $item;
			$status = 200;
I tried in on my end, seems to be working fine.
I'll try to create a PR for it if I have some time. Please let me know if the fix is good.
Update: Opened a PR - https://github.com/aimeos/ai-client-jsonapi/pull/10
Post by aimeos » 15 Feb 2021, 08:34
Thanks a lot, your fix has been merged into dev-master and 2020.10.x-dev
