Login form in custom javascript frontend
AlbertPratomo
Post by AlbertPratomo » 12 Jan 2021, 16:20
I'm building a custom javascript frontend that uses Aimeos backend. In my frontend I have a login form, through which the customer can login.
Which JSON API endpoint can I use to login the customer? Or maybe a controller / manager to do this?
AlbertPratomo
Re: Login form in custom javascript frontend
Post by AlbertPratomo » 12 Jan 2021, 17:18
By the way I'm using Aimeos with Laravel 8.
Is there a way where I can see the code for this demo page? https://laravel.demo.aimeos.org/login
That might be a nice inspiration.
Post by aimeos » 13 Jan 2021, 09:25
Login, registration and password forget isn't handled by Aimeos but by the host application instead (Laravel in your case). The login form in the demo is the standard Laravel login. Please check the Laravel documentation how you can login via API (I think you need Laravel Fortify or Sanctum packages for this).
