overwirting site template
khizar
Post by khizar » 20 Jan 2021, 12:44
i have integrated aimeos with laravel 8 and i have given a task to add extra field in site form.
When i try to overwirte the site template there are two directories in with site form is present
1) ext\ai-admin-jqadm\admin\jqadm\templates\locale\site\item-standard.php
2) ext\ai-sites\admin\jqadm\templates\locale\site\items-site.php
my aimeos app is using 2nd directorie(items-site.php) to render the site view
please tell which file do i have to overwrite in my extension and also how because there is no folder available in my
own extension(created through link given on aimeos documentation) to overwrite items-site.php
my extension folder contains
1)admin(folder)
2)client(folder)
3)config(folder)
4)controller(folder)
5)lib(folder)
6).gitignore
7)composer.json
8)manifest.php
9)phing.xml
Re: overwirting site template
Post by aimeos » 20 Jan 2021, 12:47
Name your template file item-sites.php and add "ai-sites" to the "depends" section of the manifest.php file in the root of your extension. Then, your file is used instead of that from the ai-sites extension.
khizar
Post by khizar » 20 Jan 2021, 12:54
aimeos wrote: 20 Jan 2021, 12:47 Name your template file item-sites.php and add "ai-sites" to the "depends" section of the manifest.php file in the root of your extension. Then, your file is used instead of that from the ai-sites extension.
Thank you.it worked perfectly.It would be great if you guys make some video tutorials on the customization of admin panel or
make some changes in documentation in order to make it easy for new developers because the documentation is very hard to
understand.Thanks again.
Post by aimeos » 20 Jan 2021, 13:02
Help is always welcome! Create a PR and add a clarification to the page or section where information is missing here:
https://github.com/aimeos/aimeos-docs
Don't be afraid if your sentences are not perfect, we will check, fix and extend your PR before merging.
khizar
Post by khizar » 21 Jan 2021, 06:40
aimeos wrote: 20 Jan 2021, 13:02 Help is always welcome! Create a PR and add a clarification to the page or section where information is missing here:
i have successfully added field in site form and also added a field in table by adding a file locale.php in the
directory ext\ai-moudhah\lib\custom\setup\default\schema. that file contains the following code
return [
  'table' => [
    'mshop_locale_site' => function ( \Doctrine\DBAL\Schema\Schema $schema ) {
        $table = $schema->getTable( 'mshop_locale_site' );
        $table->addColumn(  'city', 'string', ['length' => 255] );
        return $schema;
Now i want to store that field in table for that purpose i have made a decorator(following the doucmentation) in the
directory ext\ai-moudhah\lib\custom\src\MShop\Locale\Manager\Site\Decorator\Myproject.php that file contains the following code
namespace Aimeos\MShop\Locale\Manager\Site\Decorator;
class Myproject extends \Aimeos\MShop\Common\Manager\Decorator\Base
    private $attr = [
        'city' => [
            'code' => 'city',
            'internalcode' => 'city',
            'label' => 'My new column',
            'type' => 'string',
            'internaltype' => \Aimeos\MW\DB\Statement\Base::PARAM_STR,
    public function getSaveAttributes()
        return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
    public function getSearchAttributes( $sub = true )
        return parent::getSearchAttributes( $sub ) + $this->createAttributes( $this->attr );
and also i have made changes in config/mshop.php file
return [
    'site' => [
        'manager' => [
            'decorators' => [
                'local' => ['Myproject']
but the value is not storing in site table.please guide me what i am doing wrong
the field which i have added is
<div class="form-group row mandatory">
								<label class="col-sm-4 form-control-label"><?= $enc->html( $this->translate( 'admin', 'City' ) ); ?></label>
								<div class="col-sm-8">
                                    <input class="form-control item-city" type="text" tabindex="1"
										name="<?= $this->formparam( array( 'item', 'locale.site.city' ) ); ?>"
										placeholder="<?= $enc->attr( $this->translate( 'admin', 'Internal name (required)' ) ); ?>"
										value="<?= $enc->attr( $this->get( 'itemData/locale.site.city' ) ); ?>" />
								</div>
							</div>
khizar
Post by khizar » 21 Jan 2021, 07:37
would you please reply me.i am waiting for reply
Post by aimeos » 22 Jan 2021, 12:28
This seems to be wrong:
return [
    'site' => [
        'manager' => [
            'decorators' => [
It should be in ./config/mshop.php of your extension:
return [
	'locale' => [
		'manager' => [
			'site' => [
				'decorators' => [
PS: If you need immediate support, you should buy individual developer support from the Aimeos company:
https://aimeos.com/support
