How to access Aimeos Admin login/Admin panel (Laravel 8 -Jetstream) PHP 7.3
kwaku
Post by kwaku » 20 Jan 2021, 15:47
i just installed laravel 8 with jetstream and i went through the aimeos installation documentation on GitHub to install aimeos in to laravel
after successful installation, /admin sends me to laravel default scaffold dashboard.
I then changed the codes in the web.php
to
Route::middleware(['auth:sanctum', 'verified'])->get('/admin', '\Aimeos\Shop\Controller\AdminController@indexAction')->name('admin');
when i reloaded the page, i get an error that The page isn’t redirecting properly
I need help. Thanks in advance
Re: How to access Aimeos Admin login/Admin panel (Laravel 8 -Jetstream) PHP 7.3
Post by aimeos » 21 Jan 2021, 16:55
The problem is most likely that you've added 'auth:sanctum' to the /admin route instead of the jqadm and jsonadm route:
https://github.com/aimeos/aimeos-larave ... hp#L12-L14
jaynarayan
Post by jaynarayan » 12 Aug 2021, 19:56
I am having the same issue
my roite file web.php
<?php
use Illuminate\Support\Facades\Route;
| Web Routes
| Here is where you can register web routes for your application. These
| routes are loaded by the RouteServiceProvider within a group which
| contains the "web" middleware group. Now create something great!
Route::group(['middleware' => ['web']], function () {
    Route::get('/', '\Aimeos\Shop\Controller\CatalogController@homeAction')->name('aimeos_home');
Route::middleware(['auth:sanctum', 'verified'])->get('/dashboard', function () {
    return view('dashboard');
})->name('dashboard');
Post by aimeos » 13 Aug 2021, 07:08
Seems like Laravel looses the /admin URL stored in the session for redirecting after login for some reason if you go to
http://127.0.0.1:/admin
and log in using Sanctum.
wontoneesaju
Post by wontoneesaju » 04 Sep 2021, 08:40
aimeos wrote: 13 Aug 2021, 07:08 Seems like Laravel looses the /admin URL stored in the session for redirecting after login for some reason if you go to
why dont u go and fix this ?
Post by aimeos » 05 Sep 2021, 12:17
We don't kno why this happens yet. Hints and/or patches are highly welcome!
