Retrieve all media of all selection products of product
Icymars
Post by Icymars » 24 Jan 2021, 17:34
Hi guys, I need help and hope one of you can do it.
I need to get all images related to a product of select type. Which command can do it?
In code of body-standard.php in detail folder the media elements were getting with that :
$this->get( 'detailMediaItems', map() )
but if i use in products-standard.php it return: Aimeos\Map Object ( [list:protected] => Array ( ) ) 1
Re: Retrieve all media of all selection products of product
Post by aimeos » 25 Jan 2021, 09:00
The media items for the detailMediaItems property are created here:
https://github.com/aimeos/ai-client-htm ... #L547-L554
You have to pass
'detailMediaItems' => $this->get( 'detailMediaItems', map() )
to the partial to get that data in the partial too:
e.g. here: https://github.com/aimeos/ai-client-htm ... d.php#L525
Icymars
Post by Icymars » 25 Jan 2021, 10:40
So if I want to get images in product-standard.php, I've add
'detailMediaItems' => $this->get( 'detailMediaItems', map() ),
in items-body-standard.php, in catalog->list folder like this:
<div class="catalog-list-items" data-infinite-url="<?= $infiniteScroll && $this->get( 'listPageNext', 0 ) > $this->get( 'listPageCurr', 0 ) ? $this->url( $listTarget, $listController, $listAction, array( 'l_page' => $this->get( 'listPageNext' ) ) + $this->get( 'listParams', [] ), [], $listConfig ) : '' ?>">
	<?= $this->partial(
		$this->config( 'client/html/common/partials/products', 'common/partials/products-standard' ),
		array(
			'require-stock' => (int) $this->config( 'client/html/basket/require-stock', true ),
			//'basket-add' => $this->config( 'client/html/catalog/lists/basket-add', true ),
			'productItems' => $this->get( 'itemsProductItems', map() ),
			'products' => $this->get( 'listProductItems', map() ),
			'position' => $this->get( 'itemPosition' ),
</div>
and then retrieve the value from product-standard.php like this:
$this->get('detailMediaItems', [])
right?
Post by aimeos » 26 Jan 2021, 08:03
In the catalog/lists panel, the "detailMediaItems" view property isn't available. You can either create a decorator to add "listMediaItems" based on the code from the link or you add that code in the template to create it there.
