site form - add image upload
khizar
Post by khizar » 02 Feb 2021, 07:39
hey aimeos,
i want to add an image picker in my site form just like in product form.how can i implement in my custom form.
note: i have overwritten the site form and added custom field which is working perfectly now i want user to upload
logo for site so please guide me how can i achive this
can you tell me which method should i use to upload picture on server in my manager class
Re: site form - add image upload
Post by aimeos » 04 Feb 2021, 20:32
That's a bit more work to do because the media subpart in the product panel can't be used out of the box for that (it requires a mshop_*_list table for storing the relationship). For a single image, the easiest option is to use a file upload field in the template you have added and implement the handling of the file in the corresponding admin class (https://github.com/aimeos/ai-admin-jqad ... #L440-L472) that should contain code like this one:
https://github.com/aimeos/ai-admin-jqad ... #L378-L381
