Aimeos Installs wrong version
Monmon
Post by Monmon » 02 Feb 2021, 19:41
Hi, am new to aimeos and am trying to get it installed in windows. however after following the guide here "https://github.com/aimeos/aimeos#installation" when I execute the command
composer create-project aimeos/aimeos myshop
it for some reason does not install the latest version as mentioned; however it installs:-
Installing aimeos/aimeos (2018.10.3)
which gives an error cause my php version is 8.0.1. that's the error it gives
require php ^7.0 -> your php version (8.0.1) does not satisfy that requirement.
Any help is appreciated
Re: Aimeos Installs wrong version
Post by aimeos » 05 Feb 2021, 07:02
Is another PHP version installed for CLI than for the web server?
You can check and use a specific one of you use the full path:
which php
/path/to/php -v
/path/to/php /path/to/composer create-project aimeos/aimeos myshop
Post by aimeos » 13 Feb 2021, 08:46
What's the output of:
which php
php -v
