Add product to basket return out of stock error
traiyani75
Post by traiyani75 » 08 Feb 2021, 06:52
We are using Aimeos APIs into mobile application. In that, we have two stores.
Also, we are using customer endpoints to perform customer related operation.
Now, we are facing strange error when we add product to basket. Generally it should add successfully if product has stocks. But, for some user we are getting product out of stock error for every products.
"errors": [
"title": "Products out of stock"
We are not able to find the real issue for the error. Please suggest us about what problem is happening on this.
Thanks in advance :)
Re: Add product to basket return out of stock error
Post by aimeos » 08 Feb 2021, 07:35
If it's only related to some customers, it's most likely a site related issue, i.e. the customer record uses another site ID than the stock record for the product.
traiyani75
Post by traiyani75 » 08 Feb 2021, 10:18
We checked that, It is not look like site related issue.
As that user can add some products on cart, but after few insert. Process will stop automatically and returning out of stock error for all products
Pls review this video : https://drive.google.com/file/d/1WRIxp4 ... sp=sharing
