Product page still shows after setting product status to disabled
Doggiefield
Post by Doggiefield » 13 Feb 2021, 11:03
Hi
I'm using Laravel with Aimeos 19.10 - PHP 7
After I disable a product in the backend it still could be approached from the frontend. It is removed from the category view, but if I enter the url it still shows the product.
I hope someone can help me.
Re: Product page still shows after setting product status to disabled
Post by aimeos » 15 Feb 2021, 10:31
That was a bug in the aimeos/ai-controller-frontend package and has been fixed now.
Version 19.10 is only supported by the ELTS package the Aimeos company offers so you should either upgrade to 20.10 LTS or buy their extended long term support package
