MODIFY PRODUCT BASKET
marlonsamot
Post by marlonsamot » 13 Apr 2021, 12:35
Hi devs, can i modify or update product in the basket using controller? Please help newbie here. Thanks
Re: MODIFY PRODUCT BASKET
Post by aimeos » 15 Apr 2021, 06:44
Yes, use:
\Aimeos\Controller\Frontend::create( $context, 'basket' )->updateProduct( $position, $quantity );
$position is the key returnd by:
\Aimeos\Controller\Frontend::create( $context, 'basket' )->get()->getProducts();
Method description:
https://github.com/aimeos/ai-controller ... e.php#L111
