Price item not available
marlonsamot
Post by marlonsamot » 21 Apr 2021, 11:45
Hi please help with this. I have a problem it always return price item not available in this code.
        $context = app()->make('aimeos.context')->get();
        $product_id = 15; // parameter
        $quantity = 1; // parameter
        $product = \Aimeos\Controller\Frontend::create( $context, 'product' )->get( $product_id, ['text', 'price', 'media', 'attribute'] );
        $addToBasket = \Aimeos\Controller\Frontend::create( $context, 'basket' )->addProduct( $product,$quantity );
        return $addToBasket;
Re: Price item not available
Post by aimeos » 24 Apr 2021, 09:19
Does your product has a price at all?
mahmoud
Post by mahmoud » 26 Apr 2021, 01:19
I also have the same problem and the products have prices .
product_id =1 in the database after demo setup ;
        $product_id = 1; // parameter
        $product = \Aimeos\Controller\Frontend::create( $context, 'product' )->get( $product_id, ['text', 'price', 'media'] );
        return $product ;
Error:
Aimeos\MShop\Price\Exception
Thank you
Post by aimeos » 27 Apr 2021, 05:20
Is a price for the used currency and quantity "1" available?
mahmoud
Post by mahmoud » 29 Apr 2021, 00:17
Yes,
   public function addtobasket(){
        $locale = $context->locale();
        $languageid = $locale->getLanguageId();
        $currencyid = $locale->getCurrencyId();
       dd( $currencyid) ;
Display : "EUR"
But in function :
public function getLowestPrice( \Aimeos\Map $priceItems, float $quantity, string $currencyId = null ) : \Aimeos\MShop\Price\Item\Iface
		$priceList = $this->getPriceList( $priceItems, $currencyId );
 dd( "curency ".$currencyId);
https://github.com/aimeos/aimeos-core/b ... se.php#L37
Display null;
thank you
Post by aimeos » 01 May 2021, 15:42
Check the following:
1.) Is the type and list type for the prices "default" because of:
https://github.com/aimeos/ai-controller ... d.php#L235
2.) Currency parameter for getLowestPrice() is always NULL (but that isn't a problem) because of:
https://github.com/aimeos/ai-controller ... se.php#L37
cchamilt
Post by cchamilt » 08 Nov 2021, 18:00
Hi, sorry to jump in an old thread, but I am running in to a similar situation in 2021.10.
I can add the product into the normal cart, but I have to have a custom checkout process so I am trying to use addProduct. The context appears to have the right language and currency to match the product. Also, it does appear the default type and list are returning empty when calculating price.
Is there more documentation or explanation on how to add default type and list for a product?
Also, why does this code path appear to function in the normal aimeos catalog?
Thanks!
Post by aimeos » 09 Nov 2021, 10:24
Do you pass the required domains when fetching the product?
https://github.com/aimeos/ai-client-htm ... d.php#L462
cchamilt
Post by cchamilt » 10 Nov 2021, 01:24
Thanks, I am using
$product = \Aimeos\Controller\Frontend::create( $context, 'product' )->find( 'prodname', ['attribute', 'media', 'price', 'product', 'text'] );
$addToBasket = \Aimeos\Controller\Frontend::create( $context, 'basket' )->addProduct( $product, 1);
Which I believe should be using the domain correctly?
cchamilt
Post by cchamilt » 10 Nov 2021, 01:34
OK, I guess that no longer works, but looking at the code you gave me I think the following works:
$domains = ['attribute', 'media', 'price', 'product', 'text'];
$product = \Aimeos\Controller\Frontend::create( $context, 'product' )->uses($domains);
$basket = \Aimeos\Controller\Frontend::create($context, 'basket');
$addToBasket = $basket->addProduct( $product->find( 'prodname'), 1);
Hope that helps anyone else trying!
