postgresq connexion error
mahmoud
Post by mahmoud » 01 May 2021, 01:41
Hi
"php": "^7.3|^8.0",
"aimeos/ai-cms-grapesjs": "dev-master",
"aimeos/aimeos-laravel": "dev-master",
DB: Postgresql.
i use the same configuration (.env and shop.php) in the local version and hosted version.
One DB Postgresql 9.6 in Virtual server used .
when I use the local version (from 127.0.0.1) and DB in vitual server, everything is fine but when I use the same DB in web version it displays this message to me.
SQLSTATE[08006] [7] could not connect to server: Connection refused Is the server running on host "xxx.10.137.xx" and accepting TCP/IP connections on port 5432? (SQL: select * from "sessions" where "id" = ToOd40DSTQi4x9dotDXXAi4d7Ss3fAlRMJpED3pd limit 1)
Re: postgresq connexion error
Post by aimeos » 01 May 2021, 15:59
The database connection details including the credentials are different on the hosted server for sure.
mahmoud
Post by mahmoud » 01 May 2021, 19:00
Thank you for the reply.
I use GIT including .env.
File: .gitignore
/node_modules
/public/hot
/public/storage
/ext/devoext/vendor
/storage/*.key
/vendor
.env.backup
.phpunit.result.cache
docker-compose.override.yml
Homestead.json
Homestead.yaml
npm-debug.log
yarn-error.log
In my post:
git push origin master
In the hosting terminal:
 git checkout -f
 git pull origin master
 php artisan config:cache ;php artisan cache:clear ; php artisan aimeos:clear;php ./artisan view:clear ;php ./artisan route:clear
and i tested
I believe the configuration data is the same
Thank you
mahmoud
Post by mahmoud » 02 May 2021, 00:13
Now I can say that (in hosted mode) the connection to a postgresql database is only done through port 5432, even we change the port in .env and shop.php. it does not accept ports other than 5432 (if the website is hosted).
but in local mode works perfectly.
i only changed the server port and .env and shop.php to 5432.
but I don't want to use this default port
thank you
