Apply Coupon without Code
stagedive_media
Post by stagedive_media » 30 May 2021, 07:43
Hi!
I'm rather new to Aimeos and I'm having troubles with the following:
I'm having only one product in a customers shop. This product has multiple sizes and colors. The customer should get a discount when ordering a certain amount of the product not matter which size or color.
So I tried to solve this via the prices in the product settings, but that does not seem to work because it only work on variant level.
So I tried to solve it with a percentRebate and the basketvalues.total-value-min and -max decorator. This would work perfectly, but I'm only get it to work with a Coupon-Code, which I don't want. So here's the core question:
Can I apply the coupon whitout a code, automatically when a certain amount is reached?
Thank you for your help!
Re: Apply Coupon without Code
Post by aimeos » 03 Jun 2021, 09:01
Maybe you can implement a new catalog rule provider or decorator which adapts the price according to your needs:
https://github.com/aimeos/aimeos-core/t ... er/Catalog
This works in 2021.04+
