Basket custom data
devs.grapes
Basket custom data
Post by devs.grapes » 03 Jun 2021, 18:55
Hi Aimeos Team,
Aimeos Version: 2020.10
PHP Version: 7.4
Project: Laravel
Environment: Windows
I would like to ask if its possible to add custom data in the Basket session like channels = "email/sms", remarks = "test remarks", tags = "tag1, tag2, tag3", etc..?
Currently, we are using the \Aimeos\Shop\Facades\Basket class to access the Basket but can't find how to add or attach these custom data.
Thank you in advance.
Re: Basket custom data
Post by aimeos » 04 Jun 2021, 06:12
Aimeos checks if custom data is allowed so an attacker can't add arbitrary amounts of data to the basket.
You have to add a "custom" attribute to each product where you want to allow custom data in the admin backend, i.e. create three new attribute types (channels, remarks, tags) and three attributes with code "custom" and the types you've created. Afterwards, add those attributes to each product where you want to allow adding that data.
When using the Basket facade, you can pass your custom data as fifth parameter to the addProduct() method:
https://github.com/aimeos/ai-controller ... hp#L92-L94
The parameter must be an array like:
['<channel attr ID>' => 'email/sms', '<remarks attr ID>' => 'test remarks', '<tags attr ID>' => ['tag1', 'tag2', 'tag3']]
Replace the '<... attr ID>' by the ID of the custom attribute for channels, remarks and tags.
