Generate sitemap and store on S3
switch-cheehau
Post by switch-cheehau » 30 Jun 2021, 02:02
Hi Aimeos,
I would like to generate sitemap and store on AWS S3, anyway to configure the storing method?
I'm trying to use serverless architecture, hence the local storage is readonly file-system.
Re: Generate sitemap and store on S3
Post by aimeos » 01 Jul 2021, 06:03
Not by default, the sitemap files are currently stored locally:
https://github.com/aimeos/ai-controller ... #L142-L210
But you could change the code in the job controller to store the file in one of the configured file systems directly:
https://github.com/aimeos/aimeos-larave ... hp#L52-L57
The filesystem interfaces are available here:
https://github.com/aimeos/aimeos-core/t ... Filesystem
We would love to get a PR for that enhancement :-)
switch-cheehau
Post by switch-cheehau » 02 Jul 2021, 05:09
Thanks, i'll try when free
