How to modify the supplier.code address format
switch-cheehau
Post by switch-cheehau » 02 Jul 2021, 14:01
Hi Aimeos,
How do i change the address format of supplier?
aimeos/aimeos-core/lib/mshoplib/src/MShop/Service/Provider/Decorator/Supplier.php
$this->feConfig['supplier.code']['short'][$addrId] = trim( preg_replace( "/\n+/m", "\n", sprintf(
	/// Supplier address format with label (%1$s), company (%2$s),
	/// address part one (%3$s, e.g street), address part two (%4$s, e.g house number), address part three (%5$s, e.g additional information),
	/// postal/zip code (%6$s), city (%7$s), state (%8$s), country ID (%9$s),
	/// e-mail (%10$s), phone (%11$s), facsimile/telefax (%12$s), web site (%13$s)
	$context->getI18n()->dt( 'mshop', '%1$s, %2$s, %3$s %4$s, %6$s %7$s' ),
	$item->getLabel(),
	$addr->getCompany(),
	$addr->getAddress1(),
	$addr->getAddress2(),
	$addr->getAddress3(),
	$addr->getPostal(),
	$addr->getCity(),
	$addr->getState(),
	$addr->getCountryId(),
	$addr->getEmail(),
	$addr->getTelephone(),
	$addr->getTelefax(),
	$addr->getWebsite()
Re: How to modify the supplier.code address format
Post by aimeos » 04 Jul 2021, 05:50
Currently, you have to extend the class and overwrite the method. A better option would be to add
$this->getContext()->i18n()->dt( 'mshop', '%1$s ...' )
to enable translation for the address just like in the HTML clients.
switch-cheehau
Post by switch-cheehau » 04 Jul 2021, 09:54
Thanks for the reply,
Can you give me more clue how to extend that particular class? Sorry i'm still learning how to do it.
Do i have to put something in my own extention config/mshop.php
return [
    'service' => [
        'provider' => [
            'decorator' => [
                'local' => ['Supplier']
Post by aimeos » 04 Jul 2021, 14:01
Just use standard PHP "extends" syntax:
namespace Aimeos\MShop\Service\Provider\Decorator;
class MySupplier extends Supplier
	public function __construct( \Aimeos\MShop\Service\Provider\Iface $provider,
		\Aimeos\MShop\Context\Item\Iface $context, \Aimeos\MShop\Service\Item\Iface $serviceItem )
		parent::__construct( $provider, $context, $serviceItem );
Post by aimeos » 04 Jul 2021, 14:02
You can also create a PR for the Aimeos core, which is much less code to write. We will integrate it into 2021.04 too.
