CSRF mismatch when creating item through JsonAPI
JakubŽídek
Post by JakubŽídek » 13 Jul 2021, 12:30
our AIMEOS version is 2021.04 and we run PHP 7.4.3.
I am trying to create a product via the JsonAPI in our .NET 5 app.
I log in using the api/login endpoint and get a bearer token.
Then I use that for the OPTIONS in admin/default/jsonadm, where I get the CSRF token in the meta object.
Then I use admin/default/jsonadm/product?_token=+csrfTokenVariable.
This works alright in Postman and creates the product specified in the body parameter.
When I use this procedure in our .NET app, I can log in, get the options, but the last part where I create the product returns error 419 or whatever with the message: CSRF token mismatch.
The only thing that I suspect might be the cause of this is the Cookie that Postman creates that is really long. That is the only thing I do not pass to the product endpoint because I don't know how to generate this cookie in my program.
Thanks for any help, guys.
Jacob
Re: CSRF mismatch when creating item through JsonAPI
Post by aimeos » 14 Jul 2021, 05:38
Yes, you need to pass the (Laravel) cookie in the request so the framework knowns the token which is stored in the user session.
JakubŽídek
Post by JakubŽídek » 14 Jul 2021, 12:46
Thank you for the reply! How would I obtain the cookie? The login endpoint response doesn't return it.
Post by aimeos » 15 Jul 2021, 09:17
Cookies are returned as HTTP header, not in the JSON content
JakubŽídek
Post by JakubŽídek » 27 Jul 2021, 09:58
Hello again,
I have used the cookies from the OPTIONS call and still get the CSRF token mismatch error. Here is what I pass in parameters:
And here is the body I pass to the API:
What am I doing wrong? Thank you!
Post by aimeos » 29 Jul 2021, 05:25
The CSRF token must be passed as GET/POST parameter named "_token", not as cookie
JakubŽídek
Post by JakubŽídek » 29 Jul 2021, 07:21
aimeos wrote: 29 Jul 2021, 05:25 The CSRF token must be passed as GET/POST parameter named "_token", not as cookie
Thanks for the repsonse! Yes, I use the token as https://url.url?_token=TOKENSTRING. But that never worked for me, so I was trying something else.
I have now disabled the csrf in the VerifyCsrfToken.php and everything works fine. I will have to re-enable csrf when we move to production though, so fingers crossed I will figure it out.
