update problem if buy marketplace package?
Oscar
Post by Oscar » 16 Jul 2021, 15:07
Hello, I am adapting a default theme in Laravel for Ecommerce.
The views are located in resource / view / vendor / shop
I have modified the views to adapt them to the required needs and I am also customizing some files of the ai-client in / ext.
We are thinking of buying the marketplace package soon, will the work done be overwritten and I will lose progress or should there be no problems at first?
Thank you
nos3
Re: update problem if buy marketplace package?
Post by nos3 » 16 Jul 2021, 20:47
No problem, the marketplace package won't affect your own layout.
Oscar
Post by Oscar » 17 Jul 2021, 10:05
Thank you for your reply nos3. I think that anyway I will try for update reasons to extend the changes in a new extension
