Created new panel, but does not show the view
xheymango
Post by xheymango » 12 Aug 2021, 03:22
Hi all, I am really new to this Aimeos framework.
I wanted to create a new panel to add on some other new functions or system to the project. I followed these steps:
Assuming the new panel name is Point.
1. Created new extensions by following these steps (https://aimeos.org/docs/latest/developer/extensions/) with adding necessarily stuff into composer.json.
2. Created new folder in ext. ext/jqadm/src/Admin/JQAdm/Point.
3. Created Factory and Standard.php.
4. Copied list-standard.php and item-standard from other's panel (to test if the view show).
5. Added 'Point' to nav bar and gave permissions.
Edit: Followed these instructions as well. laravel-package-f18/how-to-make-new-nav ... t2146.html.
After all these steps, Point is show in the nav bar, but when clicked the Point, it show a white screen. Not too sure where did it went wrong or did I missed some important steps? Thanks in advance!
Re: Created new panel, but does not show the view
Post by aimeos » 12 Aug 2021, 07:55
There's your extension name and "admin" missing:
It must be:
ext/<yourext>/adminjqadm/src/Admin/JQAdm/Point
xheymango
Post by xheymango » 12 Aug 2021, 08:41
Hi, thanks for the speedy response!
My mistakes, actually yes, I have placed under the extension's name folder (folder name=test).
And yes, I followed the
so right now I have,
ext/test/adminjqadm/src/Admin/JQAdm/
with Point and templates (with list-standard.php and item-standard.php) in the JQAdm folder. But I will still have the same problem as previous.
Post by aimeos » 12 Aug 2021, 08:50
Check the source code if really contains nothing (then check the web server log) or of there's any output. Also have a look into the browser console for any JS errors.
xheymango
Post by xheymango » 12 Aug 2021, 08:59
I checked by right clicking at the page -> view page sources, it returns nothing. And no, there are no any JS errors. That is so weird
xheymango
Post by xheymango » 13 Aug 2021, 02:03
Solved. By adding some codes in Standard.php search() instead using return parent::search().
