Custom data domain
Custom data domain
I have same question and because that this topic is in first search result in google I ask that here.
my question is same but I use:
aimeos/aimeos-laravel 2021.07.4
laravel/framework 8.40
I want to add my custom domain (with multi tables) and manage it from aimeos jqadm?
is there any step by step document for this requirement?
- add custom domain tables migration
- add custom domain tables seeders
- add custom domain frontend and admin controllers
- add custom domain manager menu to admin
Re: Custom data domain
Create tables for new data domain:
https://aimeos.org/docs/latest/infrastr ... igrations/
To create the item/manager for a new data domain, please copy/paste/adapt an existing domain, e.g.:
https://github.com/aimeos/ai-cms-grapes ... /MShop/Cms
Add a new panel to the admin backend:
https://aimeos.org/docs/latest/admin/jq ... nt-panels/
Create a frontend component:
https://aimeos.org/docs/latest/frontend ... omponents/
Creating a frontend controller is optional and not well documented yet. It's useful if you want to extend the JSON REST API as well. Please have a look at the existing frontend controllers to see how they are implemented:
https://github.com/aimeos/ai-controller ... r/Frontend
