Client Registration Custom Email via mailgun api
tommy.developer
Post by tommy.developer » 02 Sep 2021, 08:10
Hi Good day!
I have use the default registration form as shown in the image
but I want to customize the email being sent to the user/newly register.
I am using Mailgun API only.
and also want to send email notification for a customer whenever there are promos and updates. and eventually it might behaving a configuration for email content and etc.
therefore, what I need now is a fully customize email or mailer using mailgun.
some sort of questions as follows:
  • How to do the configuration of email using Mailgun API aside from doing it in .env file?
  • How to create a fully customize email upon registration?
  • How to create a customize email for other stuff such as promos,update etc ?
  • How to implement the customize email in Client ?
that's it for now.
thanks and more power Aimeos! :D
Re: Client Registration Custom Email via mailgun api
Post by aimeos » 03 Sep 2021, 05:58
Aimeos uses the e-mail infrastructure of Laravel and the registration form including all related e-mails is provided by the Laravel authentication framework. Thus, refer to the Laravel documentation or a Laravel forum for answers to your questions.
tommy.developer
Post by tommy.developer » 03 Sep 2021, 06:26
Its already working on my end. as I run through your documentation.
thank you anyway :)
