Aimeos Product Comments and Reviews by customers
tommy.developer
Post by tommy.developer » 09 Sep 2021, 11:59
Hi there good day!
I just want to know, if How does the Product review works? as I can't find in documentation.
  • how does the the order become under review?
  • how does the review appear on customer profile?
  • what are the configurations for this product reviews?
can i have a manual or detailed documentation so that I can relay this with y team.
In addition, base on my test.
if a customer purchased a product then the customer made a review.
upon next order with same product, the customer will no longer do the review.
I think this is bug , or the customer must have a review on each item they order no matter if it is re-order.
thank and more power!
Re: Aimeos Product Comments and Reviews by customers
Post by aimeos » 10 Sep 2021, 09:09
tommy.developer wrote: 09 Sep 2021, 11:59
By default, as soon as the payment status changes to "authorized" or "received" but you can add a grace period until reviews can be done:
https://github.com/aimeos/ai-client-htm ... #L245-L289
Automatically if the conditions are met.
Mainly those two:
https://github.com/aimeos/ai-client-htm ... #L232-L256
tommy.developer wrote: 09 Sep 2021, 11:59 if a customer purchased a product then the customer made a review.
It usually doesn't make sense to ask customers for a review after they bought it a second time and those ordered products are excluded:
https://github.com/aimeos/ai-client-htm ... #L269-L287
It's hard enough to push customers to do a review at all so don't bother them with something they have already done.
tommy.developer
Post by tommy.developer » 10 Sep 2021, 11:29
got it, thanks! :)
