Locale object not available
Spixi
Post by Spixi » 03 Oct 2021, 14:30
Heyy,
I renamed my default site, now I can't access anything due to "Aimeos\MShop\Exception
Locale object not available" - vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Context/Item/Standard.php:425
I tried hardcoding the setting of Locale object - it just changes the error to " Internationalization object not available for "" "
Any help, please?
Aimeos core 2021.07.5, PHP 7.4, Linux/Mac shows the same.
Re: Locale object not available
Post by aimeos » 04 Oct 2021, 06:58
The "default" site is the only one you can not rename because it's the hard-coded fallback whenever no site is part of the URL.
Spixi
Post by Spixi » 04 Oct 2021, 15:18
Thanks, but how can I make it work again?
Post by aimeos » 05 Oct 2021, 11:32
Use phpMyAdmin or the mysql console command to update the value in the database back to "default"
