No item found for conditions product.code => test-voucher
Spixi
Post by Spixi » 10 Nov 2021, 17:59
i tried to add coupon, but I can't add it to basket due to "No item found for conditions: Array ( [product.code] => demo-percent )"
I tried running aimeos:setup, did not help.
Also, how do I reindex the catalog please?
aimeos-core 2021.07.6, php 7.4, mac
Re: No item found for conditions product.code => test-voucher
Post by aimeos » 11 Nov 2021, 06:57
Spixi wrote: 10 Nov 2021, 17:59 i tried to add coupon, but I can't add it to basket due to "No item found for conditions: Array ( [product.code] => demo-percent )"
You've deleted the rebate product that is referenced in the coupon configuration. Either recreated it or run the setup with creating the demo data again.
Spixi wrote: 10 Nov 2021, 17:59 Also, how do I reindex the catalog please?
Which host application do you use? Laravel or TYPO3?
Spixi
Post by Spixi » 12 Nov 2021, 15:43
The answer didn't help me. It still doesn't work, still the same error.
I'm using Laravel.
Post by aimeos » 14 Nov 2021, 09:46
Please execute:
