ALTER TABLE users_address ADD CONSTRAINT fk_lvuad_pid FOREIGN KEY (parentid) REFERENCES users (id) ON UPDATE CASCADE ON
chinar08
Post by chinar08 » 22 Dec 2021, 07:29
windows environment so using wamp server for server process
composer version 2.1.14
php version PHP 7.4.26
laravel version ^8.54
aimeos version 2021.10
I followed the below mentioned steps
1)wget https://getcomposer.org/download/latest ... poser.phar -O composer
2) config/database.php
'connections' => [
'mysql' => [
'charset' => 'utf8',
'collation' => 'utf8_unicode_ci',
3)php composer create-project aimeos/aimeos myshop
but still facing the issue
https://ibb.co/gVK1ZdT
How I can solve this problem,
chinar08
Re: ALTER TABLE users_address ADD CONSTRAINT fk_lvuad_pid FOREIGN KEY (parentid) REFERENCES users (id) ON UPDATE CASCADE
Post by chinar08 » 22 Dec 2021, 07:31
please provide a solution on for this as early as possible
Post by aimeos » 22 Dec 2021, 08:11
Is this a new installation of the Aimeos distribution, are you installing Aimeos into an existing Laravel application or does that happen when you update an Aimeos installation? What database and version do you use?
chinar08
Post by chinar08 » 22 Dec 2021, 09:57
aimeos wrote: 22 Dec 2021, 08:11 Is this a new installation of the Aimeos distribution, are you installing Aimeos into an existing Laravel application or does that happen when you update an Aimeos installation? What database and version do you use?
new installation and database mysql and version is 5.7.36
as per documentation for new installation command is -"php composer create-project aimeos/aimeos myshop"
and adding in preexisting project is-"php composer require aimeos/aimeos-laravel:~2021.10"
as soon as i run create project while running migration this issue comes .never got chance to run composer update or any other command as error comes on user related migrations
Post by aimeos » 22 Dec 2021, 10:07
Please use only this command without anything else and make sure you have an empty database:
chinar08
Post by chinar08 » 22 Dec 2021, 11:18
As you suggested directly run that command then i got "1071 Specified key was too long; max key length is 767 bytes"
in order to resolve this I tried again with config/databases.php
then i got same error:
SQLSTATE[HY000]: General error: 1215 Cannot add foreign key constraint: ALTER TABLE users_address ADD CONSTRAINT fk_lvuad_pid FOREIGN KEY (parentid) REFERENCES users (id) ON UPDATE CASCADE ON DELETE CASCADE
at D:\development\staging\myshop\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\DB\Statement\DBAL\Simple.php:75
71▕ {
72▕ try {
73▕ $result = $this->exec();
74▕ } catch( \PDOException $e ) {
➜ 75▕ throw new \Aimeos\MW\DB\Exception( $e->getMessage() . ': ' . $this->sql, $e->getCode() );
76▕ }
77▕
78▕ return new \Aimeos\MW\DB\Result\PDO( $result );
79▕ }
1 D:\development\bubbly\myshop\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\Setup\Task\Base.php:164
Aimeos\MW\DB\Statement\DBAL\Simple::execute()
2 D:\development\bubbly\myshop\vendor\aimeos\aimeos-core\lib\mshoplib\setup\TablesCreateMShop.php:177
Aimeos\MW\Setup\Task\Base::executeList("db-customer")
this time i followed as you said but isnt successful.
my mysql version is 5.7.36
https://ibb.co/fCTtQ72"
Post by aimeos » 22 Dec 2021, 11:51
Is it possible that your MySQL installation is creating MyISAM tables by default? The Laravel migration for its "users" table doesn't enforce InnoDB like the Aimeos code does for its tables. Therefore, creating the foreign key constraint may fail because MyISAM doesn't support them.
chinar08
Post by chinar08 » 22 Dec 2021, 12:32
yes as you mentioned i checked in db users,password,password resets,personal_access_tokens ,migrations,failed jobs has myisam type and rest is innodb .
can you kindly the locale related issue I am facing when i am install whole aimeos
Post by aimeos » 22 Dec 2021, 12:40
You have to make sure that the setup process completes without errors. Then, the required data will be there too.
