Unauthenticated message when creating item through JsonAPI
AlMarwaWagdy
Post by AlMarwaWagdy » 23 Dec 2021, 09:42
our AIMEOS version is 2021.10 and we run PHP 8.0.
I am trying to create a product via jsonadm api .
I log in using the api/login where return a token and add col in personal_access_tokens table.
Then I use that for the GET|POST in admin/default/jsonadm/product?_token=+Token.
but it return message Unauthenticated
Thanks for any help.
AlMarwa
Re: Unauthenticated message when creating item through JsonAPI
Post by aimeos » 24 Dec 2021, 07:56
You need to pass the cookie for the PHP session too e.g. for Laravel it's named "laravel_session" by default (if you didn't change the application name).
