Locale item for site "default" not found
albcamargo61
Post by albcamargo61 » 29 Jan 2022, 16:23
From the Admin interface >locales>language I changed the status of my default language from enable to review. Then following message start to raise: Locale item for site "default" not found. At this time, I have no web access.
What is my simples solution?
Thanks,
Alberto Camargo
aimeos shop: alcari.corefex.net
Linux version 4.15.0-101-generic (buildd@lgw01-amd64-003) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04))
PHP 7.2.24-0ubuntu0.18.04.4 (cli) (built: Apr 8 2020 15:45:57) ( NTS )
Composer 1.6.3 2018-01-31 16:28:17
Laravel Framework 6.18.14
npm -v 6.14.4
node v12.16.3
albcamargo61
Re: Locale item for site "default" not found
Post by albcamargo61 » 30 Jan 2022, 17:12
Any help?
Post by aimeos » 31 Jan 2022, 07:38
Use PHPMyAdmin or the MySQL client to set the status of the record in the mshop_locale_language table to "1" again.
Which Aimeos version do you use? In newer versions, this shouldn't be a problem any more.
albcamargo61
Post by albcamargo61 » 31 Jan 2022, 15:32
There is some reason for no answer. Isn't there?
Post by aimeos » 31 Jan 2022, 15:39
aimeos wrote: 31 Jan 2022, 07:38 Use PHPMyAdmin or the MySQL client to set the status of the record in the mshop_locale_language table to "1" again.
albcamargo61
Post by albcamargo61 » 03 Feb 2022, 12:00
aimeos wrote: 31 Jan 2022, 15:39
Aimeos 2021.07.12. I got the update advice in my admin panel. I tried to update it according to the instructions but is not working. With the composer update command a red long screen is rising. Some help, please
Post by aimeos » 04 Feb 2022, 09:59
Without posting the error output, there's no way to say what could be wrong ...
albcamargo61
Post by albcamargo61 » 05 Feb 2022, 03:40
Problem solved when I updated composer version to 2.2
