Displaying the nested categories in the menu
Stefanki
Post by Stefanki » 02 Feb 2022, 17:21
I'm trying to do something with the menu displayed by creating the categories in the administration interface:
When i mouseover the name of the categories there is a sub menu that appears to show a list of sub categories.
However sub-sub categories will not appear in the sub menu until i click on some of of the categories.
I have tried to use the "client/html/catalog/filter/tree/deep" and it seems that it make the menu displays all sub categories too, but it displays them without regards to their depth level.
Example:
If the categories are organized like this:
A-->(A1,A2,A3)
A1-->(A11,A12)
B-->(B1,B2)
When hovering on "A" it will display: A1 A11 A12 A2 A3
But i would like the sub-sub categories (A11, A12) to be visually distinct from the other one.
For example by being displayed in italic or by making a new menu appears when hovering them.
My aimeos version: "aimeos/aimeos-core": "2021.04.*"
I have used the utility to create a aimeos extension to be able to fiddle with those files without breaking the rest of the code.
There are 4 files in the templates, tree-body-standard, tree-partial-2ndlvl, tree-partial-custom, tree-partial-standard
Also src/Client/Html/Catalog/Filter/Tree/Standard.php seems to be the class that implements it.
I am not really sure of what i am doing, should i try to modify this code or am i missing something ?
Thank you by advance
Re: Displaying the nested categories in the menu
Post by aimeos » 04 Feb 2022, 09:22
You should update to 2021.10 LTS first because 2021.04 adn 2021.07 are not supported any more.
To display a megamenu for example, you can add this in the Option/Value table of the category which should display the megamenu:
- Option: css-class
- Value: megamenu
Furthermore, you can change the number of category levels which are displayed using this configuration setting:
https://aimeos.org/docs/2021.x/config/c ... els-always
Stefanki
Post by Stefanki » 08 Feb 2022, 14:52
Thank you very much, i will try to do something with those informations !
