Avoid GET requests for delete operations
createanet
Post by createanet » 09 Feb 2022, 10:43
Currently using 2020.10.*, I notice a change was introduced July/2021.
https://github.com/aimeos/aimeos-larave ... fa3ff69270
This is now preventing me from removing items from the import/export panel.
Reading the comments on the commit it references changes on `ai-admin-jqadm`. I already have `ai-admin-jqadm:2020.10.x-dev` in my project and this fails to make any difference. The reference here also seems unrelated to the dashboard, but rather the order list and the confirm-delete vue component.
Looking into themes/dashboard.js this fails to contain any hooks on elements in order to intercept the event and make a POST request.
I tried testing this on the 2021 demo, but I don't think you have a schedule job running to process exports so they never appeared on the demo dashboard for me to execute.
Any clues please?
Thanks,
Re: Avoid GET requests for delete operations
Post by aimeos » 10 Feb 2022, 15:20
You are right, deleting export jobs in the dashboard was not possible any more due to adding strict security measures to prevent XSS attacks. The is now fixed and you can test the latest version using:
composer req aimeos/ai-admin-jqadm:2021.10.x-dev
createanet
Post by createanet » 10 Feb 2022, 15:44
Thanks guys,
This package had a dependency on aimeos/aimeos-core 2021.10.*. However as I mention we are stuck on 2020.10.*. We don't have the option/budget to upgrade at the moment.
Not sure what to suggest other than patch it and roll it back, but I can also understand why this was changed.
Do you have any other suggestions please?
Post by aimeos » 10 Feb 2022, 15:56
The change are only these few lines:
https://github.com/aimeos/ai-admin-jqad ... hp#L47-L53
You can copy the template to your own extension and replace the appropriate lines with the new ones.
