Features in GrapeJS
karpati
Features in GrapeJS
Post by karpati » 17 Feb 2022, 15:08
Hello!
Is it possible to turn on features in GrapeJS admin that I see on grapejs.com?
E.g.:
The most important are:
- Style manager tab: to add a class to an element
- Source code
Useful:
- Fullscreen
- Layer manager tab: view all elements in a tree structure
Thank you!
Re: Features in GrapeJS
Post by aimeos » 18 Feb 2022, 08:23
karpati wrote: 17 Feb 2022, 15:08 - Style manager tab: to add a class to an element
- Source code
Yes, you can add custom code to the GrapesJS configuration object where you can add the necessary settings here:
https://github.com/aimeos/ai-cms-grapes ... s#L79-L204
In your admin/jqadm/themes/custom.js of your own extension, use:
Aimeos.CMSContent.GrapesJS.panels[4] = {
			buttons  : [{
				command: 'open-sm',
				className: 'fa fa-paint-brush',
				command: 'open-tm',
				className: 'fa fa-cog',
				command: 'open-layers',
				className: 'fa fa-bars',
				command: 'open-blocks',
				className: 'fa fa-th-large',
karpati wrote: 17 Feb 2022, 15:08 - Fullscreen
This one is already available.
karpati
Post by karpati » 19 Feb 2022, 08:33
It works, thank you very much for your help.
I couldn't find the file "admin/jqadm/themes/custom.js" (and it didn't work when I put it there)
so I copied the code to the file "admin/jqadm /js/custom.js".
And it needed index 3 instead of index 4 because "impexp" is commented out by default.
Aimeos.CMSContent.GrapesJS.panels [3]
Post by aimeos » 20 Feb 2022, 22:29
It's important that you add it to your own Aimeos extension you've created for your project. Otherwise, it will be overwritten as soon as a new aimeos/ai-admin-jqadm package is available and you run "composer up".
