Looping page refreshes for non-logged-in users
santfather
Post by santfather » 01 Mar 2022, 15:02
Laravel version: 8.80
Aimeos version: 2021.10
PHP version: 8.0.8
the problem is for unregistered users. if you don't log in, the page is constantly updated. this is observed only on the main page. the catalog /shop page is working correctly. after registration, the problem disappears
Re: Looping page refreshes for non-logged-in users
Post by aimeos » 03 Mar 2022, 08:54
This may be caused by the redirect in the header template of the aimeos/ai-cms-grapesjs package.
Please make sure you have installed at least version 2021.10.5 which removes that code.
If this is not the problem, please check if you have a custom redirect in your code or routes/web.php file.
