How can I rename properties?
karpati
Post by karpati » 06 Mar 2022, 15:40
Hello!
I imported a lot of products that have properties.
I see the properties here:
Catalog / Products / [my product] / Characteristics / Properties
Everything is awesome.
The names of the properties are not in my own language, I want to translate them.
If I change the property name in the "Types / Product properties" (Product Property Types) section,
it will not change for the product.
I can see that the name has changed in the "mshop_product_property_type" table,
but unfortunately it doesn't refer to products with an ID.
What is the easiest way to rename properties?
Re: How can I rename properties?
Post by aimeos » 08 Mar 2022, 07:03
If you want to translate property TYPES, you have to add translations, e.g.:
- https://github.com/aimeos/ai-client-htm ... y.php#L452
- https://github.com/aimeos/ai-client-htm ... po#L59-L73
