I want to extend the order entity
rud99
Post by rud99 » 25 Mar 2022, 16:37
Hello!
I want to extend the order entity.
I want to add a new field.
I don't understand which entity I need to expand order or order_base?
I want to use this https://aimeos.org/docs/2021.x/models/e ... properties
Thanks!
Re: I want to extend the order entity
Post by aimeos » 28 Mar 2022, 07:17
The mshop_order_base table represents the stored basket whereas the mshop_order table is like an invoice and you can have several entries in the mshop_order table for one order in mshop_order_base.
rud99
Post by rud99 » 28 Mar 2022, 07:19
Thanks!
