Filters
karpati
Filters
Hi!
The filter on the catalog page also displays attributes that are not relevant to that category.
How do I set it to not show attributes from another category?
For example:
First category:
Red and blue products
Second category:
Blue and green products
When I look at the first category, the filter shows red, blue, and green colors.
There is no green product in the first category, so it should not be shown in the filter.
For example:
First category:
Second category:
Re: Filters
The attributes are always in the filters but you can hide them using the catalog/count JS if there are no products available for that attribute:
https://github.com/aimeos/ai-client-htm ... dy.php#L19
karpati
Re: Filters
If I remove disabled items, the ones that are relevant in that category will also disappear after the first click in the filter.
I only want to remove attributes that are not specific to any product in that category.
Is there a way to do that?
Re: Filters
The default behavior should be that the attributes with no product number are disabled and if one attribute type has no attribute active attributes, than the complete attribute type with all attributes is hidden.
The only other way would be to store the attribute types that are relevant to the category somewhere so the frontend knows if the attribute type should be displayed at all. But that requires a custom implementation.
