Help with orders list
rud99
Post by rud99 » 28 Mar 2022, 11:36
Hello!
I watn to use my orders data from "mshop_order" table in updateAsync() method.
I saw https://aimeos.org/docs/latest/models/m ... er-methods , but i can not apply it in my case.
I did so in my custom payment provider:
$manager = \Aimeos\MShop::create( $context, 'order' );
$filter = $manager->filter(true);
$filter->add( 'id', '==', 73 );
$items = $manager->search($filter, ['order']);
I did not get results.
Thanks!
Re: Help with orders list
Post by aimeos » 29 Mar 2022, 08:43
"id" is not a valid search key, but "order.id" would be.
There are also methods available in service providers which simplifies retrieving data:
https://aimeos.org/docs/latest/provider ... order-item
rud99
Post by rud99 » 29 Mar 2022, 13:01
I solved my problem with orders list, but I have new ). This code change my "order.statuspayment" in order object, but I have problem with $this->saveOrder($order); in method. It construction interupt scrip
    public function updateAsync() : bool
        $manager = \Aimeos\MShop::create($this->getContext(), 'order' );
        $search = $manager->filter(true);
        $expr = [
            $search->compare( '==', 'order.statuspayment', [
                \Aimeos\MShop\Order\Item\Base::PAY_UNFINISHED,
                \Aimeos\MShop\Order\Item\Base::PAY_PENDING,
                \Aimeos\MShop\Order\Item\Base::PAY_AUTHORIZED] ),
            $search->compare( '!=', 'order.transaction_id', null),
        $search->setConditions( $search->and( $expr ) );
        $items = $manager->search( $search );
        if ($items) {
            foreach ($items as $item) {
                $transactionId = $item->get('transaction_id');
                dump($transactionId);
                $response = ***get bank response ****;
                $status = $this->statuses[$response->status];
                $order = $this->getOrder($item->getId());
                $order->setStatusPayment($status);
        return true;
I have new status in order after $order->setStatusPayment($status), but I have a new firld ".statuspayment" in order with old statuspayment value. Old status = 4. New status = 2.
https://disk.yandex.ru/i/LkqgkYrrEhgKHw
rud99
Post by rud99 » 30 Mar 2022, 11:06
I solved problem. Problem was in my Decorator
    private $attr = [
        'order.transaction_id' => [
            'code' => 'order.transaction_id',
            'internalcode' => 'mord."transaction_id"',
            'label' => 'Bank transaction Id',
            'type' => 'string',
            'internaltype' => \Aimeos\MW\DB\Statement\Base::PARAM_STR,
I deleted "order."
    private $attr = [
        'transaction_id' => [
            'code' => 'transaction_id',
            'type' => 'string',
