Product filter
David
Product filter
Post by David » 04 Apr 2022, 12:36
Why is this filter not working?
$productFilter->add($productFilter->and([
	$productFilter->is($productFilter->make('product:prop', ['vendor_code', null, $productData[0]] ), '!=', null),
        $productFilter->is($productFilter->make('product:prop', ['barcode', null, $productData[8]] ), '!=', null),
 ]))->add( 'product.type', '==', 'default');
$productManager->search($productFilter->add('product.type', '==', 'default')
          ->add($productFilter->make( 'product:prop', ['vendor_code', null, $productData[0]]), '!=', null)
          ->add($productFilter->make( 'product:prop', ['barcode', null, $productData[8]]), '!=', null));
And this one works
And this one works
How to query for two properties?
Re: Product filter
Post by aimeos » 06 Apr 2022, 09:36
That doesn't work because relational databases join tables and records this way:
id, code, label, propertyid, propertytype, propertyvalue
1, 'prod', 'Test', 10, 'vendor_code', 'abcd'
1, 'prod', 'Test', 11, 'barcode', '1234'
Thus, there will be no joined record with contains both property types/values.
TGergo
Re: Product filter
Post by TGergo » 09 Jan 2023, 14:27
I have two questions:
There is a product attribute called Author with many names.
The promblem is, filter dropdown does not include all names.
And other.
Can I list the suppliers by number DESC?
Thank You!
Re: Product filter
Post by aimeos » 11 Jan 2023, 09:11
There's an internal (configurable) limit how many items are fetched in one request to mitigate DoS attacks. You can increase the limit using this setting: https://aimeos.org/docs/2022.x/config/c ... /#max-size
