How can I overwrite billing address(checkout process) from laravel controller function
Re: How can I overwrite billing address(checkout process) from laravel controller function
Post by aimeos » 26 May 2022, 08:37
The address is added to the basket and if you change the address afterwards, the address in the basket is still the copy of the original address. To update the address in the basket, you have to add the new address to the basket again to overwrite the old one.
Post by aimeos » 29 May 2022, 07:07
You don't have to delete the previous address in the basket. Instead, you can overwrite it by passing the same type and position (usually 0) when using the basket controller:
https://github.com/aimeos/ai-controller ... #L128-L136
