Customize View File
HitendraKakadiya
Customize View File
Post by HitendraKakadiya » 30 May 2022, 10:29
How can I modify the view in aimeos?
Even though there is some view which is not found in the code how can I find it?
Re: Customize View File
Post by aimeos » 30 May 2022, 10:30
Which views do you want to customize?
HitendraKakadiya
Post by HitendraKakadiya » 30 May 2022, 10:33
I need to change the product group view. I need to add a one-click event on that "Add to basket" button if there is a "0" quantity selected.
Post by aimeos » 30 May 2022, 10:46
Here's the template for the catalog detail groups:
https://github.com/aimeos/ai-client-htm ... /group.php
Please also read the article about customizing the frontend HTML code:
https://aimeos.org/docs/latest/frontend ... templates/
In case you only want to add JS code, then you should add this to a JS file you include into your layout, e.g. the ./public/js/app.js for Laravel.
HitendraKakadiya
Post by HitendraKakadiya » 30 May 2022, 10:57
I need also a button view which is on that group page which is for "add to basket".
HitendraKakadiya
Post by HitendraKakadiya » 30 May 2022, 11:07
Thanks for your help. I also got a button view.
