Get Parent Id from catalog
Bananamoon
Post by Bananamoon » 22 Jun 2015, 09:16
I am trying to get the Parent item from a Catalog item through the parentid, however there doesn't seem to be a getParentId function available. I also tried with other functions (like searchItems) with no success whatsoever.
Is there any way I am missing to get this parentid/item?
Thanks for the help!
Re: Get Parent Id from catalog
Post by aimeos » 22 Jun 2015, 09:28
Bananamoon wrote: I am trying to get the Parent item from a Catalog item through the parentid, however there doesn't seem to be a getParentId function available. I also tried with other functions (like searchItems) with no success whatsoever.
The catalog items don't link to their parents and you can traverse them only downwards.
If you want to retrieve all parents of a node up to the tree root, you can use the getPath() method of the catalog manager:
https://github.com/aimeos/arcavias-core ... t.php#L437
