Payrexx with Aimeos
Re: Payrexx with Aimeos
Post by aimeos » 10 Jun 2022, 07:48
The documentation for the Omnipay Payrexx driver is a bit thin:
https://github.com/payrexx/omnipay-payrexx
What you need for configuration is:
apiKey : <your api key>
instance : <instance>.payrexx.com
Next thing is that the driver is not conforming to Omnipay standards because of this data required:
    'psp' => 36, // Payrexx Direct
    'skipResultPage' => true,
    'successRedirectUrl' => 'https://www.merchant-website.com/success',
    'failedRedirectUrl' => 'https://www.merchant-website.com/failed',
The correct URL keys would be "returnUrl" and "cancelUrl". Both, as well as "psp" and "skipResultPage" needs to be added in a custom getData() method like here to make it work:
https://github.com/aimeoscom/ai-payment ... #L268-L271
