Best way to add a default supplier to new products
yeh
Post by yeh » 19 Jul 2022, 13:41
Hi
My Aimeos setup has multiple sub-sites. I have also created a single supplier for each sub-site. What is the best way of automatically assigning each sub-site's supplier to all newly created products automatically?
e.g. Sub-site 1 is assigned the supplier Supplier-1. I would like all Sub-site 1's products to automatically be assigned Supplier-1 as the supplier.
Would it be better to use a decorator or to override the Aimeos\AdminJQAdm\Product\Supplier\Standard class?
Re: Best way to add a default supplier to new products
Post by aimeos » 20 Jul 2022, 11:04
The easiest way might be a decorator adding the supplier to the view so it will be displayed by the supplier subpart template and automatically added if it's not removed manually in the supplier sub-panel.
yeh
Post by yeh » 27 Jul 2022, 08:25
This is a good idea, thank you.
