Divide order product
Armenia
Post by Armenia » 27 Jul 2022, 14:24
Hi.
In this case I should divide order product, when product quantity is greater then 1.
For example, when quantity is equal to 4, I have to save this product in 4 different rows at database (In each row quantity is equal 1).
How can I implement this ?
Re: Divide order product
Post by aimeos » 28 Jul 2022, 04:56
Should the basket also show four lines if the customer have chosen a quantity of "4"?
Armenia
Post by Armenia » 28 Jul 2022, 08:25
Only after basket 'Summary' step.
Post by aimeos » 28 Jul 2022, 10:28
You can overwrite this method in you own order base manager implementation:
https://github.com/aimeos/aimeos-core/b ... #L561-L611
Armenia
Post by Armenia » 28 Jul 2022, 11:45
Thank you !
