Categories on sub-sites
yeh
Post by yeh » 10 Aug 2022, 12:31
I'm using the marketplace extension, and have set up all catalog categories on the main parent site. Child sites inherit these categories. Is it possible to set different media and/or text for categories on sub-sites?
Currently if I switch to a sub-site and then edit the text or media for a category it affects the category on the parent site meaning I can't change the slider images for sub-sites as any changes also affect every other sub-site and the parent site.
nos3
Re: Categories on sub-sites
Post by nos3 » 12 Aug 2022, 06:52
You are likely using the marketplace mode (sitelevel = 3), where the items are inherited to child sites AND aggregated to the main site. If you use sitelevel = 1, only inheritance is performed and you can add different texts and images to the sub-sites for the inherited categories.
yeh
Post by yeh » 12 Aug 2022, 10:11
Ah okay. I don't think I can use this mode as I need the products from each sub-store to be available on the main store.
