Shipping and handling cost dependent of the amount of items
Mirco
Post by Mirco » 02 Sep 2015, 18:32
Hi
I configure at the moment the shipping cost and need some help.
I would like to calculate the shipping cost dependent of the amount of items at the basket.
For example:
1 item = 1.45 Euro
2 items = 2.60 Euro
3 items = 3.20 Euro
4 items and more 4.50 Euro
Maybe there is something in the documentation but I'm to dumb to find it :?
Or need I to write a Decorator for this behavior?
Re: Shipping and handling cost dependent of the amount of it
Post by aimeos » 02 Sep 2015, 19:48
Mirco wrote: I would like to calculate the shipping cost dependent of the amount of items at the basket.
For example:
1 item = 1.45 Euro
2 items = 2.60 Euro
3 items = 3.20 Euro
For linear shipping costs, you could have used "costs per item" for each product but you have a cut after four items so you need to create your own decorator. You can use the "MShop_Service_Provider_Decorator_Costs" as reference.
Mirco
Post by Mirco » 04 Sep 2015, 07:28
Thanks!
I have done my one Decorator "Delivery.php". The base was the Costs.php Decorator as suggested.
I changed the function calcPrice( MShop_Order_Item_Base_Interface $basket )
I'm note quite sure if this the right way but it works.
	public function calcPrice( MShop_Order_Item_Base_Interface $basket )
		$config = $this->getServiceItem()->getConfig();
		if( !isset( $config['delivery.amount'] ) ) {
			throw new MShop_Service_Provider_Exception( sprintf( 'Missing configuration "%1$s"', 'delivery.amount' ) );
		$count = 0;
		foreach( $basket->getProducts() as $product )
			$count += $product->getQuantity();
		$price = $this->_getProvider()->calcPrice( $basket );
		if ($count == 1) {
			$price->setValue( 0.0);
			$price->setCosts( 1.45);
		} else if ($count == 2) {
			$price->setCosts(2.40);
		} else if ($count == 3) {
			$price->setCosts(5.0);
		} else if ($count > 3) {
			$price->setCosts( 6.8);
		return $price;
Post by aimeos » 04 Sep 2015, 08:41
Mirco wrote:I'm note quite sure if this the right way but it works.
Looks good :-D
This seems to be unnecessary but you can use the configuration to let the shop owner change the prices himself.
Decorators shouldn't reset the prices but add their costs like this:
$price->setCosts( $price->getCosts() + $amount );
Thus, you can stack several decorators which all calculate their additional costs :-)
