Change Main Banners in Berlin Theme
briajer
Post by briajer » 18 Oct 2022, 19:15
How can I change the main banners in the Berlin Theme?
I have located the config reference here:
/home/aimeos/myshop/vendor/aimeos/aimeos-core/setup/default/data/demo-catalog.php: 'url' => 'https://aimeos.org/media/default/main-banner-1-big.webp',
Changing the URL and restarting Apache didn't make a difference.
Any help with this would be appreciated.
Re: Change Main Banners in Berlin Theme
Post by aimeos » 19 Oct 2022, 07:08
If you want to change the category images (home page content is from the root category and it's sub-categories), go to the Catalog > Categories panel, select the category and click on the "Media" tab where you can add or replace the images.
briajer
Post by briajer » 19 Oct 2022, 20:39
It's not the categories media, I have managed to add those for categories I have created.
It is the 3 default slides/banners that are part of the Berlin theme.
main-banner-1
main-banner-2
main-banner-3
These are referenced directly to the Aimeos website aimeos.org/media.
I will probably have to go down the route of custom theme but would like to quickly change the 3 images if possible?
Post by aimeos » 20 Oct 2022, 11:06
These are images of the sub-categories you can change in the Catalog > Category > Media panel.
briajer
Post by briajer » 20 Oct 2022, 11:44
Thanks, Easier than I though it would be.
I was digging through the php files
NeilM
Post by NeilM » 09 Oct 2024, 14:01
Not sure I understand - I look under categories and I still dont see where the banner images are referenced (XAMPP Windows)
Post by aimeos » 10 Oct 2024, 07:31
You have to click on the category where you want to change the stage image and go to the "Media" tab. There, you will find (or can add) the image with type "Stage".
